Brinkmann fein phono stage with volume control
anon_bb
Honey Badger
Due to upgrade to a balanced and customised solution I am now looking to sell my Brinkmann Fein phono stage with matching granite base. This unit has gain settings for MM plus 2 high / low output MC settings. It also has selectable loading settings. The final output stage also incorporates a volume control enabling you to connect directly to a power amp if you are "single source" - or through an external switch into the power amp if you also have other sources with volume control or need to connect a preamp for additional source control. Going direct gives a massive gain in sound quality - going direct to a power amp the Fein sounds better than a TEAD Groove into the Vibe preamp, even though TEAD phono / preamp is one of the best combinations around.
New price is almost two grand - looking for £1000.
