box building
Here you can see the front, side and bottom pieces. The Bottom measures 380x356 as I am using 12mm MDF and 18mm MDF front and rear baffles- bit easier than grinding a bit of 18mm away to make the driver and amp sit flush
close up of one of the side panels. Note the bits of 18mm mounted ontop of the panel. This should make the box much stronger and provide more support.
and using some bathroom sealant from a bathroom (surprisingly) project 12months ago we stuck the pieces on.
another mockup showing the pieces in position.
starting on the top and bottom pieces, we need to only put extra mdf strengthening pieces on the top and bottom to strengthen the baffle and amp mount panel
a finished side panel
note the MDF split- we cut against the grain so that when the screws are finally in the finished article they are going in the grain ergo stronger
This is B&Q £10 a big **** off sheet as my dad works there and gets discount. Probably best to use better MDF
And a finished top panel
some of todays finished work
to come- mounting drivers, fitting the bracing panels, fitting the 12mm and 18mm MDF pieces together at either end etc etc. If you click on my home audio pic you will see my Vaessen speakers are painted grey with nicely rounded off edges. I'm hoping to get the sub to look like that or just nicely veneer it.
