bypass 70v/100v transformer on eaw vr21 speakers
i bought 6 jbl control 28 commercial speakers/i found utube video how to bypass 70v transformer to use speakers on 8 ohm home stereo/that worked /on my eaw vr21 i need help to bypass transformer/also i seen post they might have to be rewired due to wrong wire for home use/is this true/any feedback would be helpful/i picked all 8 up for 150.00
I don't understand what 'wrong' wire for home use means. Wire is wire. If you open up the boxes and remove the transformer, you then connect the cables that went to the transformer to the rear terminals. Just make sure you keep them phased correctly, with the same colours going to the same terminals on all 8 units.
S.
