For Sale: Cambridge Audio 840a integrated amp
Scotland
Boxed with manual and remote this is a very nice amplifier, punching well above it's weight. Balanced and single ended in.
Spec:
Power Output: 120W RMS into 8 Ohms
200W RMS into 4 Ohms
Input Impedance: Input 1 (balanced) 20 kOhm
Inputs 2-7 20 kOhm
Tape Input 20 kOhm
THD (unweighted): < 0.001% 1 kHz at 80% of rated power
< 0.01% 20 Hz - 20 kHz at 80% of rated power
Frequency Response: 10 Hz - 50 kHz +/- 1 dB
Signal to Noise Ratio: > 93 dB
Power amp damping factor: > 110 at 1 kHz
Standby 7W
Bass: Max bass boost/cut +/- 10 dB at 10 Hz
Treble: Max treble boost/cut +/- 7.5 dB at 20 kHz
Dimensions (H x W x D): 115 x 430 x 385mm
(4.5 x 16.9 x 15.2ââ'¬Â)
Weight: 15.0kg (33Lbs)
Very impressive amp, only problem is surface mark above the display - see pic, which I've made as obvious as possible. Hence price of £275 plus delivery.
Sold thanks.
Now anyone interested in the 3.5m pair of 8TC, or will it be the 'bay for them?
