I-S
Good Evening.... Infidel
So as not to derail the photo thread, all equipment discussions can come in here
So, what gear do you use? What made you choose that? What's good, what's bad about it? What would you change (money permitting)?
My kit:
Canon EOS 5D
Canon EF17-40 F4L USM
Canon EF 24-105 F4L IS USM
Canon EF 50 F1.8 (mk I)
Canon EF 70-200 F4L USM
Canon EF 300 F4L IS USM
Canon EF 1.4X
Canon EF 2X II
Canon Speedlite 550EX
Manfrotto 681B Monopod
Manfrotto 441 Carbon one tripod
Markins M10 Ball Head
RRS/Wimberley plates
Many camera bags (crumpler budgie smuggler, tube'o'lager, shrinkle, CCS Mammoth, CCS pouches, Lowepro pouches, Kinesis belt, and looking to get a Think Tank Speed Freak). Conclusion: there's no perfect camera bag.
I use the 5D because I like full-frame. I've had two APS-C crop DSLRs, and just never really got on with them. I like the narrower DOF, larger viewfinder and wider FOV of full frame. The 5D isn't a brilliantly fast camera (although with the right technique it is good enough at in-flight tracking), but canon haven't yet made the camera I want (take the AF performance, processing speed and AF system customisation from the 7D, mix with the F8 AF from the EOS 3, and wrap it around the sensor/viewfinder of the 5D II in a body the size and weight of the 5D II with about 5FPS and you'd be about there).
I'm very happy with my lens kit; the only change I'd like to make would be to change the 70-200 for the IS version. I like the F4 L series lenses as they're significantly lighter than the F2.8 versions, but optically very much on a par. If I could afford I would get a 300 F2.8L IS though...
The one area where I feel I have gone wrong is on supports - I spent far too much on the tripod, and yet barely use it. I think I used the monopod once.
My kit:
Canon EOS 5D
Canon EF 1.4X
Canon EF 2X II
