I have recently to a much larger location I have two Vintage Chario Hiper sub woofers. I have only ever used one in my system, now I wish to connect both together in safe way for both the speakers and the amp. each Speaker is identical and houses a push pull config The specs are for each speaker are as follows
one 250 mm paper subwoofer LEFT (shielded)
one 250 mm paper subwoofer RIGHT (shielded)
each unit double-voice coil / long-throw type
92 dB SPL 2.83 V / 1m
35/120 Hz @ -3db
flat top 4th order
150 Hz (HIPER BASS + HIPER 1000)
4 Ohm
rated for 50-120 W / 8 Ohm
440x580x470
35 Kg
On the rear of each speaker are eight terminals 4 per channer (2 x R in & 2 marked R sat out)
I would be grateful if someone can inform the correct wiring for the two speakers together, I want to use the two channel output from an Arcam 8 amp to drive them which has a low end impedence range of 4 ohm per channel...... No response from Chario they don't appear interested in thier legacy products and nothing about Hiper Sub on The web, it is strange as they were expensive when bought......Waiting desperately
35/120 Hz @ -3db
flat top 4th order
4 Ohm
440x580x470
35 Kg
