I have been busy with the Dynamat Original and Blue tack in my CD Player. I managed to get through 1m x 0.5 m on the my NAD c521i (single layers only) so lots of areas are covered including the floor of the player.
Promising results so far.
However, I heard a while back that copper sheeting can be used in CD Players.
My questions as follows.
1, What is the theory (is it to reduce RFI) ?
2, Is it best installed to the inside of the lid or on the floor ( under the main circuit board) of the cd player or both. (the inside of the lid would be easier though)
3, Does it matter how thick the copper plating is ?
4, Does the majority of the copper's surface area have to be exposed or could i sandwich in between two layers of Dynamat ?
Any help would be good.
Thanks.
Iain,
Thanks.
Iain,
