- Sep 1, 2005
Hi there
Can anyone help me pin down what may be the problem with my Crimson 640D mono Amp.
Symptoms
The amp runs very hot when switched on but playing any music. The fan kicks in after about 5 mins but it keeps getting hotter and shuts off after another couple of mins. Playing music through it just makes it worse.
History
The problem began today as I was swapping speaker cables about. Have I shorted something and caused the problem? Or is is a parts deterioration issue and a common problem with these amps?
They are not worked hard, play at low to medium levels and the right channel mono is working fine.
I've access to multimeters etc but don't want to mess about inside whilst it is switched on.
Symptoms
History
