DC Cable recommendations?
Southampton
I'm looking to source some cable to connect a SMPS to a Power Amp module. It has to be soldered into 1.5mm holes on the PCB and rated at about 300W. Any recommendations for a good performance cable that I can get from RS, Farnell or Maplins?
10A per 1mm^2 conductor area is fine, so it doesn't have to be huge stuff - the Van Damme speaker cable on offer at the mo. at Maplin would be ideal.
I'd be far more worried about keeping loop area down to minimise EMI - tightly twist or bundle together the + and - conductors.
No No No.....
the insulation is not rated for mains or higher ...but agree with the twist.
look for a ptfe insulated stranded core...of suficient dia to carry the current you need.
