I'm considering making some interconnects using Maplin Shark Coax cable (N61AR) it has silver plated copper core and PE insulation. OK so far so goo. The one thing (major thing!) is that I don't know which bits to connect to where in the plugs. I assume I use the core on one connection and the braid on the other! Is this right. Also is this cable going to be OK or would I be better using something else (Pref from Maplin).
Cheers all
Donut
Cheers all
Donut
