Just been to put some final touches to my new subs at my mate's workshop today.
Boy are these big muthas
I have asked WM to post some pictures, as I don't have the facility. We are now at the stage of applying the wadding. As a first go I have used Dacron, getting fibreglass was impossible in the UK sadly. the 9oz fibrefill expnds to about 19mm, which is a problem. Do I use double layers or try it with just the one
An alternative would be 1" foam, but Falcon are out of stock and I cannot get any from elsewhere. So we'll start off with the Dacron.
The cabinet is built using 25mm MDF, with a 38mm front baffle. The extensive bracing is fitted to grooves in the sidewalls, and all joints use biscuits, glue and screws. We wnt for the sloping sides as much to reduce the apparent bulk as to help with standing waves.
The cabinets weigh at least 60lbs each, and that's before we put the 40lb drivers inside
So any thoughts on damping would be helpful and might save hours of trial and error! Should I wrap Dacron around the braces or will they be OK left as they are?
Michael
Michael
