- Aug 28, 2018
I'm having troubles finding a solution to the following problem -
My current set up includes two Rokit 6 powered monitors, an Audio Technica at-lp5 direct drive turntable, and a laptop. I would like to find a way of connecting both my turntable and laptop to my speakers at the same time (but not to use together) as a way of not having to change wires around every time i want to use one or the other, however within this I would also like to add a way of controlling the EQ for both inputs. Although the music i listen to varies a lot from my laptop, the music i play from the turntable is usually bass heavy dub which i would like to emphasize through the use of EQ adjustment, however would like a solution that works with both the laptop and turntable because im lazy and don't like changing wires around.
Iv tried software EQ's on the laptop however after some use, they all randomly generate a harsh, loud distortion noise for no apparent reason. Iv also tried the SZ-MIX04 mixer, however although it worked with the laptop, it wouldn't work with the turntable unless it was connected through an RCA input, with in affect bypassed the EQ function on the mixer.
Any help would be appreciated.
Thankyou,
Zach.
Thankyou,
Zach.
