DPA Enlightenment Dac servicing
I have recently bought one of the above and although it sounds fine I have heard that because it is 25 years old, the caps might benefit from renewing. Can anyone recommend a person or company to do this and perhaps upgrade any other components
It's unlikely the caps will need changing as they have a very long life, and 25 years is not that old. i have 50+ year old capacitors working fine. Similarly, there is nothing in a simple DAC that needs upgrading, or would result in an improvement in performance. I would only get the item looked at if I had any reason to think it wasn't working to specification.
If it ain't broke.....
S
electrolytic caps have a limited life expectancy. so it is well worth getting them replaced before they fail and take something else out that might not be reparable. It that has not been done in 25yrs then it important is should be done.
Yes, but have you thought through just what the life of a capacitor actually is? Capacitors have a rated life, say of 8000 hours at a rated temperature, typically 85degrees. Now, capacitors have a doubling of life for every 10degrees lower temperature, so at a typical temperature of, say, 45degrees inside the capacitor, that means that the life will be 128000 hours or 175 years if used two hours a day! Seriously, capacitor ageing is a non issue for any modern electronics under 50years old except valves which may run hotter.
Unless the capacitors are bulging, leave them alone!
S
Yes it may still work. And yes, you will hear a sound improvement if you change to new fresh caps.
It's certainly a problem on DPA DACs, in fact I've repaired several which were not working at all due to faulty electrolytics, including my own.
If you've not already got it sorted and still want to you can PM me to arrange to have it done.
