External Crossover enclosure
Buckinghamshire
Hi there,
It's been a while since I last signed in and like many of us engaged in various projects mine have been a little slow in moving forward. However, I am now very close to finishing the Rogers JR149's and the only little detail I am struggling with at present is finding a suitable enclosure for the crossovers.
In the original design the crossovers are built onto a circular PCB and mounted inside a very thin pressed steel case at the foot of the speaker. This provides terrible isolation to the speaker in soooo many ways so I will be mounting the crossovers externally on the rebuilt speakers (keeping the metal bases but these have been acoustically treated inside and filled with lead shot).
What I am looking for is an aluminium enclosure with a clear Perspex/acrylic lid. Need to be at least 6" square but 4" deep as some of the upgraded crossover components I am using will need a greater depth than the original metal base provides.
Anyone help with recommending enclosure suppliers? Maplins and CPC don't have anything...
