FS Stands Unique Sound Tower
I have one of these surplus to requirements if anyone is interested. It is the standard version with 6mm glass shelves (5 in total including the top and bottom).
See http://www.standsunique.com/productrange/support/hifi/6mm.htm
There are 2 issues:
1. I foolishly sprayed the legs matt black a few years back and they now look a bit scuffed. Could do with another coat!
2. Some of the plastic pads on the shelf supports are not as firmly glued to the brass pins as they might be and tend to wander as you push them in - this is irritating rather than really problematic as you just have to slide them back into position before placing the shelves.
On the other hand it works pretty well for keeping kit off the floor etc.
Pick up (from between Ilford and Romford) preferable given the weight of glass involved, but I could pack it securely and send it if needed.
Not really sure how much it's worth... Any offers?
stand
hi been looking for one of these but I am some distance away from you (stoke on trent) could you pm me a price as if you are willing to wait a little I would probably take it from you.
Rgds
Darren
