Help selecting bluetooth receiver
Loughton, Essex,UK
Hi All
Please excuse my ignorance but I am looking for a DAB receiver that includes a Bluetooth transmitter and I am not sure what exactly I should look for in the spec.
eg One spec stated ""Bluetooth SBC/AAC"" does this define what I need? (Yamaha RX-AS710D)
Lots of units state "Bluetooth" but they only RECEIVE sound from iPods etc so are not what I am looking for.
I have severe hearing loss and use an Oticon "Connect-line Streamer" This device pairs with any Bluetooth unit such as a mobile phone or MP3 player and allows me to hear sounds transmitted directly to my hearing aids. I am hoping to find a receiver that will also do this.
Chris
Another option is to get a conventional DAB receiver but then also buy a Miccus "Home RTX" Bluetooth unit.
This is a very small device which either acts in 'transmit' or 'receive' mode (in your case, 'transmit'), takes the RCA feed from your DAB receiver (L+R) and sends it out using Bluetooth v2.1. In fact, I would think you don't actually need a DAB receiver ... what is ideal for you is just a DAB tuner - which is designed to send its output to a preamp (which then feeds a power amp which drives the speakers). You won't be listening to speakers ... or, rather, the speakers you will be listening to are your hearing aids! :)
I use 2 of these RTX units (1 unit set to transmit, the other set to receive) to transmit the signal from my satellite TV box to my preamp, so I can listen to my TV through my hifi system. They work perfectly!
Contact Thomas at Miccus ("[email protected]") who should be able to confirm whether the RTX unit is compatible with the version of Bluetooth your hearing aids use - and also tell you where you can buy it from.
Good luck,
Andy
