How to hook up 5.1 to PC
I am moving into a new room. I have the space to set up a 5.1 system but I am having trouble figuring out what components I need and what is compatible with the output from my PC.
I built my PC a few years ago. It does not have a dedicated sound card but the MB does have an SPDIF port. The motherboard of the PC is Asus Prime x370-pro. The SPDIF port is on the motherboard.
Can someone help me figure out what components I need to get a 5.1 system running? I would like it to sound comparable to my mid-range headphones. I am not shooting for top of the line stuff but somewhere from mid range to the 80% solution.
I am looking at something like the Klipsch Reference Theater pack, but I don't know if I need an amp and/or receiver in between my PC and the speakers.
I am really a full noob when it comes to audio so any info is appreciated.
As an Amazon Associate we earn from qualifying purchases.
You will need a 5.1 channel receiver that will take the USB output of the PC and provide 5 outputs to the loudspeakers, which will need go wired to the receiver output, and the 0.1 subwoofer output which is connected wirelessly to the sub itself.
If not a full receiver, at the very least you'll need a 6 channel USB sound card and a 5 channel amplifier. The sub has it's own amplification.
Depending on where you're located, you need to find a local dealer to advise on specific models.
S
