ISOkinetik ISOvert 3P Dynamic VTA Adjuster
mainscablesrus
The Mains Man
In stock now, a must for all Rega owners. ISOkinetik ISOvert 3P - 3 Point Rega tonearm VTA adjuster TYPE 1
The ISovert 3P is a dynamic VTA or Vertical tracking angle adjuster allows for setting of accurate VTA on 3 point Rega tonearms suitable for RB100, RB101 RB201,RB251, RB303, RB301, RB700 and RB1000 also OEM and derivative Rega 3 point mounting tonearms including ISOkinetik, Michel, Cabezon, Origin live, Nad, Goldring
Many turntables in particular Rega turntables will require the mounting hole to be widened to 26mm (currently 24mm) in order to accept the ISOvert 3P
The ISOvert 3P 3P is also useful when fitting 3 point Rega tonearms turntables with higher platters as it can be used to provide necessary height
The tonearm is bolted into the ISOvert 3P 's threaded top plate, adjustment to VTA is made by adjusting the stainless steel Knurled ring, there is no need to take the arm off the turntable to audition various settings as no spacers are used and the whole assembly is mounted to the turntable by a quick release knurled brass locking nut
The kit is supplied with fixing bolts and allen wrench, recently reviewed in HIFi Choice and awarded 5 stars. £79.95 available now from my website here.
