JVC Skipping CD Player
Hi all, CD player help request here:
  • JVC UX-D750
Random occurrences of pausing/skipping during play. I've already done the routine:
  • Cleaning laser lens
  • Cleaning and greasing rails
It continues to pause/skip every now and again, with the sound of gears whirring/searching. Really frustrating. Just wondering if anyone has had similar experiences with this mini hifi system or might know some more methods to fix. Thanks
How old is it? If it were an old unit, I would look at the laser for output and/or servo alignment, but with something more recent like yours, I suspect a fault. If still under warranty, you may get it repaired, if out of warranty, sadly the cost of repair may well exceed its value.
If you have a friendly tech who has the right facilities, they may be able to identify the problem.
S
Thanks for your reply! Yeah it's out of warranty unfortunately, so I'm just gonna do my best DIY maintenance.
It's strange because I can't decipher any patterns on when it decides to skip. But it sometimes happens on the first tracks or towards the ends of CDs.
Interestingly, there is one CD that I use to test if I've managed to fix it, and it will often skip at the ends of track 2 and 4, so I feel there is something to it.
