Hopefully some one can help me with this?
I recently bought a mains filter which has iec connectors on it and I am in the process of rewiring my mains cables and the cable into the filter as per TNT tts.
This is fine with standard kettle type leads on the amp & cd player etc but I have a Roku soundbridge which has a 2.5mm plug into the soundbridge and a fixed standard 3 pin plug at the mains end can anyone advise me on what I need to make a new lead for this and if in fact there is any point in doing it?
All and any help would be greatly appreciated
Thanks
Power supply
M1001: 110V or 220V power supply, depending on region
Input: 100V or 240V (depending on region), 50/60Hz;
Output: 5V, 1.5 amp
http://www.rokulabs.com/products/soundbridge/specs.php
Thanks
Power supply
Output: 5V, 1.5 amp
