Hi Jimmy
Yes it is definatley worth doing, your system will be considerably quieter and the results in the low freq will be very noticable, much more control and deeper bass,clarity,timing and seperation will all improve
But if your gonna do it then do it right.
If your consumer unit is split so you can add a trip fuse to the non protected side (the side that is not covered by your RCD unit) Your house lights and possibly your freezer may be on the unprotected side,then you will not need a seperate consumer unit.
You can use either a ring main or a radial there are huge arguments for both (i personally used a radial). But the most important thing here is to come directly from your unprotected side of the consumer unit from just one fuse fed directly to the wall sockets for your system, or the sockets you will plug your mains block into if you use one. Do not install seperate ring main or radials for different parts of the system i.e do not use more than one fuse in your consumer unit for lets say one ring main for the amps and one for the source components this is a big no no (unlike a big mistake made by a reviewer some years ago)
Absolutely everything in your sytem must be fed from one source in the consumer unit.
If you are going to go to this extent in your mains supply then i can highly recommend the Hi Fi or High Current woven ring main cable by Kimber it really is excellent. Otherwise use the lowest impedance cable you can find.
In your post you mention the last few feet of power cable being important. Well you are absolutely correct the last meter of cable into your equipment is paramount above any ring main or radial supply. But i also got excellent results from wiring my listening room with a dedicated radial.
Regards
ergman
www.manger-audio.co.uk
