- Jun 22, 2008
I bought these from a guy on eBay about 10 months ago, they've served me well and sound fantastic considering the price I paid for them. They're based on Merlin's high end TSM speakers, and sound great with acoustic/jazz and any kind of laid back music. However if you're into dance/metal or anything hard/bass heavy you might as well stop reading here, otherwise here's some more info.
(copy and pasted from the original eBay description which I saved for info etc...).
this auction is for a set of quality magnetically shielded speakers, made by a skilled enthusiast from superb quality components. His description follows. I can confirm everything here - these are extremely well constructed units, with outstanding performance, although I would recommend quite a punchy amp to drive them properly. I'm very reluctantly parting with these after rationalising my equipment and relocating my system to a smaller room, which calls for smaller speakers (Royd Edens, in case you were wondering...).
These speakers began life as a design similar to the Highly regarded Award winning Merlin TSM standmounts, details found here: WWW.MERLINMUSIC.COM .
They use high class drive units from Morel - If you haven't heard of Morel then you really are missing out, they are quite similar to Dynaudio (hardly surprising as they started out together), thus they incorporate the same design features and high quality build, resulting in their near identical look.
Morel units have long been the drivers of choice for many of the worlds finest speaker makers, among them: www.Duntech.com.au , www.egglestonworks.com , www.wegg3.com , etc...
When I first made these they were fitted with the exact same driver arrangement as the Merlin's - a Morel MW164 6.5" woofer and a Morel MDT-30 Tweeter. However after continued listening, tweeking and testing of the speakers I found my prefered match was to use a similar but more compact shielded tweeter from Morel's range (the MDT-39), this allowed me to easily recess the tweeter and accurately time align the drivers (something not possible using the MDT-30 with it's larger faceplate).
The speakers themselves are solidly constructed, using a differing thickness dual layer method with intensive extra internal bracing (all assembled using Marine grade Epoxy Resin - no cheap weak PVA glue used here), they are finished in gloss black with 1/2" solid mahogany side panels. The result of this is the speakers are incredibly strong, solid and inert (with wall thicknesses all 1" at least) a perfect start for producing the very best sound.
Here are some specs:
Sensitivity - 87db/w
Impedance - 8 nominal
Freq Response - 55hz to 20khz +/-3db
Size - 14.5"H x 8"W x 12.5"D
The speakers are single wired (I tried bi-wired/Bi-amped but found no advantage) sealed designs (tried ported but prefered sealed), using symetrical 2nd order (12db/oct) filters on both tweeter and woofer, acoustic damping felt is fitted around the tweeters - this is to help eliminate any possible diffraction effects.
I had thought of fitting grilles, in fact I did when I first made them - but they were removed, as I prefered them uncluttered - if needed I would suggest using acoustic foam attached using velcro pads (as used by Wilson Audio) thus reducing any possible ill effects of both speaker cloth and frame (easily found on ebay).
These speakers really do sound terrific, I have compared them against many more expensive speakers and they always proved their quality (displaying a much smoother/more even in room frequency response, which no doubt helps them produce their wonderful natural sound).
These really are a bargain - if you were to buy just the drive units alone it would cost more than my auction price (these drivers are normally used in speakers costing £1500-£4000 a pair, or more if mated with larger woofer), added to that the high quality crossover components and cabinet and these are an absolute steal.
Fast forward to now, we've cleaned up the cabinets considerably - my dad who is a decorator by trade sanded off the heavy gloss and applied a satin black matte finish to them. We also had some grilles made up for the fronts. They look much better now (though not perfect) and sound great.
I am asking £235 for these (what I paid altogether) which really is a bargain for what you're getting. The guy who sold them to me is right, they're great speakers and were a big step up from the Epos m5s we were using before them. To buy the drivers/parts alone you would be looking a lot more money that this.
Anyways, enough with the hard sell
They weigh about 15kg each so they've got to be pick up only I'm afraid (based in South Wales, near Cardiff). Auditions/try outs are more than welcome, though you'll have to bring your own amp(s) as we've switched to some active ADM9 speakers instead.
Pics are available here -
One other thing to mention is that the bottoms were not touched as no one sees them, so they still have the high gloss mahogany finish
If anyone's interested let me know. I'd like to keep them but unfortunately they're too big to store any longer so they've got to go. The speakers they're based on retail for $2100 so you're getting a lot of speaker for the money
Dawson
Dawson
