For Sale: Naim 52, naim ps, nap250, nac72, hicap, nj boards, chord indigo plus, naca5
NAP250:
One of the last ones made. Built by an employee in 2002 and hence no serial number. Full service by Naim in 2010. Original box, leads, instructions, service receipt etc.
£1100 delivered within the UK.
HiCap:
Serial number is 96758. Fitted with new Kendeil capacitors and an Avondale regulator board a year ago. Comes with power cable, 5pin-5pin SNAIC, blanking plug and original packaging.
£400 delivered within UK.
NAC 72:
Serial number is 110604. CD input unlike earlier units. Comes with all boards including a set of 323K/5 MC phono boards, power cable, original packaging & a full set of replacement capacitors should it need serviced at some point.
NJ 321/729 Boards:
Basically brand new. Shipped over from the states from Neil and only used for a handful of hours. Latest spec built to order.
£160 Delivered within the UK. Overseas will be slightly more.
NACA5:
Can't remember if it's 6m or 6.5m. Fairly sure its 6.5m. Banana plugs at one end and Naim plugs on the other. Black.
£125 delivered within the UK.
