Need advice on Home Theatre Floor Standing Speakers
I'm a newbie. I got a Denon AVR-X250BT home theatre amp.
This is what's written on the Denon catalogue: The AVR-X250BT AV receiver powers quality home theater at 130W per channel.
However on close inspection, it says
Number of Poweramps: 5
Power Output (8 ohm, 20 Hz - 20 kHz, 0.08% 2ch Drive): 70 W
Power Output (6 ohm, 1 kHz, 0.7% 2ch Drive): 90 W
Power Output (6 ohm, 1 kHz, 1% 1ch Drive): 130 W
I've shortlisted two floorstanding speakers:
1) Pioneer SP-FS51
Frequency Range 45 Hz-20 kHz
Nominal Impedance 6 Ohms
Sensitivity (2.83 V) 87 dB
Maximum Input Power 130 W
Crossover Frequency 2.5 kHz
Tweeter 1"
2) Yamaha NS-F51
Minimum Frequency Response 43 Hz
Crossover Type 2-way
Sensitivity 89 dB
RMS Output Power 80 W
Impedance 6 Ohm
Maximum Frequency Response 26 kHz
Driver Type 25.40 mm Soft Dome Tweeter
Speaker Configuration 3.0
PMPO Output Power 240 W
I'm confused. What am I supposed to see in a speaker? Ohms? Watts? Sensitivity? Can anyone help me out? Also, which would you choose from the two I've listed? Thank you.
Of the two listed, neither specification means anything. Frequency response is meaningless without dB limits. Sensitivity is meaningless without impedance, and impedance is meaningless without showing an impedance against frequency graph.
Power handling is meaningless without stating distortion levels and frequency.
In other words, these specifications are derived by the Marketing Department, not Engineering, and are just random numbers.
Unless you can find proper reviews with meaningful measurements, you might as well buy on looks.
S
