New (2nd hand) integrated amp advice
Hi all, I'm conisdering a replacement amp for my impending 30th and I'd appreciate you thoughts and advice.
My main criteria are: my main source is my TT (MM cart at the mo), although I also use CD, radio and a digi box). It will be used to drive a pair of Rega R3's which I have no plans on swapping for a long time.
It must look good. It must work well at low (as well as high volumes) - i have kids - and live in a large solid wood floored flat. Not that bothered about a remote and although i would prefer headphone socket, the type of amp i'm looking at won't include this.
So far i'm considering:
Sugden A21a (not the current one) or a Stemfoort if one pops up
John Shearne phase II
Alchemist forsetti, or Nemesis if I can find one
thanks in advance.
ps. anyone selling one of these?
How about a basic Lavardin IS - it works very well at low levels and shows all the qualities of their more expensive amps. You can get it on ebay for £500-600 if prepared to wait.
I'm very happy with the Unison Research Unico that I have now (I picked up mine for £400 2nd hand). I'd previously owned an A21a and had been looking for another, but bought the Unico instead, and now I no longer want an A21a ;).
Cambridge Audio 840A v2 (new) plus a 640P phono amp
Exposure XV/Super XV which has a superb phonostage (MM or MC, but not both). Would work very well with the R3's.
Aforementioned Rega amp (Mira 3).
thanks all for this. i like the look of those Lavardin, never heard of them before. will investigate further...
I have for sale...
an Audio Analogue Puccini Settata if you're interested? it has a phono stage, certainly ticks the box on looks. see classifieds for info. cheers!
Thats valves isn't it?
I am nowadays a fan of valves...
...good sound stage!!
It's a hybrid; valve pre and mosfet power. I was missing some bottom end welly from my previous all-valve setups and was getting a bit tired of failing output valves, so went half and half! It's very nice especially since I swapped out the stock ecc82's for some nos mullards, smooth treble and powerful bass......happy days :)
