Audiologica
Audiologica Ltd
- Feb 12, 2009
We are now taking pre-orders of this amazing little box, high-quality DAC, headphone amp and pre-amp.
Indicative price is £329, currently taking deposits, stock available from 1st March straight after the Bristol show. The unit will be on demo at the show together with the Nuforce CDP-8 CD player/transport.
We have a demo model in right now and early indications are very favourable.
http://www.audiologica.co.uk/nuforce_hdp.html
[email protected]
01403 789226
The Nuforce Icon HDP incorporates a full-speed USB DAC and full-function S/PDIF D/A converter, plus a headphone-amplifier circuit and preamp output. Supporting digital USB, S/PDIF in coaxial and 3.5mm optical (3.5mm) modes, along with an analog line input, the HDP's flexibility has been designed to accommodate all manner of audio devices. Icon HDP is expected to compete with other DAC and preamp costing up to several times its price.
As the heart of the music enthusiast's desktop system, the NuForce Icon HDP works in perfect harmony with the NuForce Icon Amp/30 as a physically small yet impactful audio system.
Note: Icon HDP uses the same DAC as the high-end CDP-8 (MSRP $1450.00) and similar preamp as P-8S (MSRP $1650.00).
Features:
* USB 2.0 Full Speed compliant and 1.1 supported, 8-96kHz/16-24-bit
* S/PDIF input: Coaxial up to 192kHz/24-bit or Optical up to 192kHz/24-bit
* Analog input: 3.5mm or RCA input
* Audiophile-grade DA converter
* Low-distortion, high-current headphone amplifier
* High quality analog volume control
Specifications:
* Analog Inputs: RCA or 3.5mm when inserted
* Digital input: S/PDIF - Coaxial or 3.5mm Optical when inserted. Coaxial up to 192kHz/24-bit or Optical up to 192kHz/24-bit
* USB DAC: USB 1.0 and 1.1 up to 44.1kHz/16-bit, USB 2.0 Full-Speed up to 96kHz/24-bit
* RCA Output: 2.6 Vrms (cuts off when headphone is inserted)
* Headphone Output: 6.3mm full-size headphone output jack.
Headphone power spec:
o 288mW rms @ 30 Ohm
o 210mW rms @ 120 Ohm
o 152mW rms @ 300 Ohm
o 123mW rms @ 500 Ohm
o 96mW rms @ 600 Ohm
o 59mW rms @ 1200 Ohm
o 43mW rms @ 1700 Ohm
o 35mW rms @ 2000 Ohm
* THD+N: 0.001% @ 1kHz
* Frequency response: 10Hz to 100kHz (-0.5dB)
* SNR > 100dB
* Power Requirement: 15V, 1.6A, 100-240VAC (Worldwide AC)
* Dimension: 6" x 4 1/2" x 1"
* Weight: 1 lb
Package Contents Include:
*Toslink to optical mini adapter
* 6.3mm stereo plug (male) to 3.5mm stereo connector (female) adapter
* USB cable
* Silicone stand
* AC adaptor (15V, 1.6A, 100-240VAC)
[email protected]
01403 789226
Features:
Specifications:
* SNR > 100dB
* Weight: 1 lb
* USB cable
* Silicone stand
