Hello.
Reading the instructions with my gram amp 2, the company seems to recommend using "CT100 standard co-axial cable" for the interconnects.
Well in maplins, their equivalent is FT100 (code XS17T).
I'm planning on making my own IC's using the Shark phono plugs (AQ57M) and thought about Naim's advice re: siting their phonostage inside LP12's to minimize delicate signal path between the arm and the stage. So I plan on making a 30cm IC going from deck->gramAmp, (i can sit the stage behind the deck/ or suspend below the shelf) and then a 70cm IC to reach the PrimaLuna.
1) Firstly, is the FT100 co-ax cable good enough or could I get a better one for not much more? (ft100=99p/m)
2) Will it really matter between 30cm I plan to make, or will a 100cm (giving me more leeway re:siting) be just as good?
Cheers for any help
PS alternatives to the FT100 would be:
2: http://www.maplin.co.uk/Module.aspx?ModuleNo=125&doy=27m11D
or
3: http://www.maplin.co.uk/module.aspx?ModuleNo=9512&doy=27m11
or
4: http://www.maplin.co.uk/module.aspx?ModuleNo=131&doy=27m11
I haven't made IC's before and am not sure what would fit the bill, but the last option (4) looks good too
Cheers for any help
or
or
