pics
Shropshire
Hi
I was looking for the picture thread but couldn't see it.
Which do we think looks better version 1 or 2?
I've just obtained a more recent copy of Adobe; having a play. ;)
I assume you meant to compare where you'd adjusted white balance/brightness/contrast etc, but it's impossible to compare as No.2 has been horribly compressed.
Personal preference is for the first. The second seems a little over saturated to me.
I've never bothered to properly calibrate my monitor, but from here I'd guess the reality is somewhere between the two?
Yes, I've got a running disagreement with my Dad.
He likes no 2 but then he always uses too much saturation for me.
I agree, somewhere between the two.
Is he viewing through the same monitor as you?
The majority of monitors will display things differently - add to that peoples' own eyesight and opinions, and you're opening a can of worms! :)
to improve a lot of pics the simple thing you can do is auto levels (CMD/CTRL+SHIFT+L) and auto balance (CMD/CTRL+SHIFT+B)
The to improve on that and bring out that you can just duplicate layer bring up the levels again (CMD/CTRL+L) and adjust he middle point till you get the right detail in the dark areas then delete parts of that layer as required.
the attached was only a quick example
