I guess a lot of people have the same dilemma - too many plugs, not enough sockets...so you have to use an adapter/board for some equipment and maybe can only plug in one piece of kit directly to the wall. But (assuming plugging in directly provides cleaner power due to the shorter path):
* how do you decide which unit should have its own dedicated socket?
* should it be the source or the amp.;
* ...and if the amp., which - phono stage, pre- or power?
* does the answer vary with the source?
* is the only satisfactory answer a complete re-wire with a dedicated ring main and enough sockets to take all your equipment?
Or does none of this matter a toss?
And while we're at it, if you have aftermarket power cords, but not enough to go round, which unit should get the fancy lead?
