PS reconfiguration - help please!
West Riding
Hi
I have acquired a Power-one HB5-3/OVP-A power supply to use with my Sqeezebox. It is currently configured for US voltage and I obviously need to reconfigure for UK use. However I'm a dunce and need some help.
The info on the case says that for 230 vac:
Jumper - 2 & 3
Apply AC - 4 & 1.
The input terminals are numbered :
5 1 3 2 4 (in that order).
Therre are currently jumpers between 2 & 4 and between 1 & 3 (which is consistent with what it says for 120vac config). There is also a flatish circular component (told you I was a dunce) across 3 & 2.
Changing the jumpers seems straightforward but I have some questions:
1. Does it matter whether I apply live or neutral AC to 4 or 1 ?
2. Do I leave the circular component where it is?
3. Which terminal do I attach the earth to ?
Any kind soul out there who can advise me?
Rgds
Ian
A pic of the thing would speak volumes !
the circular jobbie is likely to be a 22nf cap [?] or similar
This is a pic of the input terminals. In this view the teminals are numbered left to right, 4 2 3 1 5.
Can anybody shed any light on my queries?
As I said ...I can see where the in coming ac is attached pins 1 and 4 with a jumper on 2 and 3.....my reasearch suggested that the earth is attached to the chasis of the unit [in fact ive a farnell psu that does the same] as to the cap I think it goes from l to neutral.
can anyone more knowlegable give a more definative answer ??
