Ok so I have been out of the audio loop for a few years now as I now focus on networking for my work. I recently aquired a Quad 405 amp from a friend and wanted to know if I can connect my older Sony STR AV770
receiver (80W) as a preamp to the Quad. I know there are a set of RCA u-plugs on the back of the Sony apparantly to be used for an equilizer in series if desired. I was wondering if iremove the jumper plugs and redirect the audio out from the Sony to the Quad if this will work? I dont want to over drive the Quad though. I just had the gear at home and cant afford a Quad 44 preamp even if i mod it for 120VAC line voltage. The Quad needs a power circuit cap replacement and possibly some other upgrades. The final speakers are Bose 501 II's
Any advice? Can I use the Sony or should I look for another pre-amp solution.
Matt
Matt
