the pre is stuffed with rather good and useful tone controls ....had a quick scoure of the web ....using the way back machine using this address..
http://www.quad-hifi.co.uk
goes back to april 97 but doesn't give downloads of the manuals like later versions
these are the specs for the 77 int [if you don't have them ]
Quad 77 int.
Signal Bus: Up to 32 77-Series productsInputs: Source 1, Source 2 and Tape
Inputs Source 1&2 Tape
Input sensitivity 100 or 300 or 775mV 100 or 300 or 775mV
Load Impedance 33kOhms 33kOhms
Signal/Noise >100dB >100dB
Outputs Preamp Out Tape Out
Output level 775mV same as input level
Source impedance 850Ohms 300Ohms
Interchannel balance:
+/-0.1 dB with volume control varied from maximum to -70dB
Maximum Power Output:
84W into 8Ohm <0.5% dtot 115W into 4Ohms <0.5% dtot
Maximum Current Output:
11A peak per channel
Distortion (total harmonic):
Continuous sine wave into 8Ohm resistive load
20Hz any level up to 70W <0.005% (22kHz bandwidth)
1kHz any level up to 70W <0.005% (22kHz bandwidth)
20kHz any level up to 70W <0.01% (80kHz bandwidth)
Output internal impedanceand DC offset:
1.5µH in parallel with 0.05Ohm, DC offset <20mV
Frequency response:
-0.3dB at 20Hz and 20kHz
(ref 1kHz): -3dB at 3Hz and 50kHz
Power response (ref 1kHz):
-0.75dB at 10Hz and 20kHz
Crosstalk:
<-90dB at 1kHz
Hum and Noise:
-105dB ref. 75W (22kHz measurement bandwidth unweighted)
Stability:
Unconditionally stable with any load and any signal
AC input:
110-120V or 220-240V, 30-350VA, depending on signal level
Weight:
6.3kg
Dimensions:
321mm wide; 65mm high; 300mm deep
this shows that you can alter the input selectivety of each input ..via the handset effectively used to match inputs of say a cdp with a high output ....
It will be worth contacting quad to get the remote control codes or go experiment with one of those universal units ...you may get lucky and find the hiden features ....
but it will be worth having a chat with quad to see if they can send you the schematics and user manual for the unit.
