Recording from Mixer's headphone out to Zoom f3
India
Hello !
I record live concerts to my zoom f3.
I understand that recording from the XLR out on the mixer is the best practice.
Most of the times the mixer in the concert venues only has 2 xlr outputs that are used up by the speaker.
Even the 1/4" jack output would be used up, leaving me only with the headphone out
I want to know if connecting a 1/4" male jack to XLR male converter and connecting the 1/4" to the headphones out and the XLR to the zoom f3 would damage the f3 and how will it affect the sound quality
Are there any work arounds that are suggested ?
(Zoom f3's source is set to "LINE" and no additional effects are applied during recording)
Thanks In advance
Hello !
Thanks In advance
Hey there! You're on the right track using the mixer's XLR outputs is ideal, but when those are already in use, tapping the headphone jack becomes an option... though it's a bit tricky.
First off, your Zoom F3 can absolutely accept line-level signals if you set the input to "LINE" in the menu, just make sure it's set correctly for the input you're using. That said, headphone outputs aren't really designed for recording, they're meant for listening. The level and impedance can be pretty hot and might not play nicely with the F3, potentially causing distortion or noise.
A better option, if your mixer allows, would be to send a signal from an aux out or control room out directly to the F3's XLR input. If that's not possible, you could use a cable with an inline pad or attenuator to safely drop the headphone signal down to a level the F3 can handle. So yeah, it can work, but you'll want to keep an eye on levels and maybe test a few volume settings first to avoid clipping or distortion. Let me know if you want help figuring out a cable setup that keeps things clean!
Thanks a lot for your response !
A little context :
I am a performing violinist. Usually at the concert venues all the XLR out/ Line out jacks would be used up. Leaving only the headphone output available.
More often than not, I won't have any control over the level the sound operator sends to my f3. On top of that, f3 being a 32 bit float recorder, I cant truly rely on the waveform that's shown on the f3's display. ( I also toyed with the idea of connecting an analog VU meter to the f3 to accurately get a sense of the headphone output levels)
(Also the mixers vary from venue to venue)
This being said, what do you think about using a DI box ?
the headphone output goes into the DI and the output of DI goes into f3
Regards
A little context :
Regards
Just to be clear, everything below is hypothetical and based on general audio signal behavior. Always double-check signal levels and gear specs before connecting anything, especially in live settings.
That said, using a DI box could work as a workaround. It would help balance the signal and make it more manageable for the F3. But most DIs expect instrument-level signals, not the hot, amplified signal from a headphone jack, so without attenuation, you could easily overload the input. You'd likely want to put a stereo inline pad or attenuator before the DI to bring the signal down to a safer level. You're also spot on about the 32-bit float display not being super useful for catching analog clipping. A VU meter inline could give a better real-time read, especially with unpredictable signal levels coming from random venue boards.
Again, definitely proceed cautiously since you're dealing with an amplified headphone signal feeding into pro gear not really built for that.
Okay, so DI boxes come with a -15 db pad. Are you saying that even -15 db pad is not enough to bring down the signal ?
In that case, how much should the signal coming from the mixer's headphone out be attenuated (just an approximation) before undergoing a further attenuation of -15 db ?
A built-in -15 dB pad on a DI is helpful, but it might still not be enough depending on how hot the headphone output is. Headphone jacks can push out signals way above line level, sometimes peaking around +15 to +18 dBu, especially if the mixer's volume is cranked. A safe target level for the Zoom F3's line input is around +4 dBu (standard line level), so you'd ideally want the signal attenuated by 20 to 30 dB total to be in a comfortable range. That means if the headphone out is really hot, a -15 dB pad alone might leave you halfway there.
If your DI has a switchable pad (like -15 dB or -30 dB), use the higher one if needed. If not, adding a passive inline attenuator before the DI, like an extra -10 or -15 dB pad, could help. It really depends on how loud the headphone signal is, but more than one stage of attenuation is often the safest bet with this kind of setup.
Let me know what DI you're using or considering—I can help figure out a combo that works well for your needs.
