Thanks for the replies all. Sounds like its worth a go. NOt sure I'd trust meself with a soldering iron mind. Maybe its time to learn. Shouldn't think a project gets much simpler than that.
Originally posted by Snoo
<snip>
Incidently Uncle Ants, on a side note. I also own a Focus One but with an SME arm. Have you made any mods to it other than the Rega?
Hi Snoo,
A couple of very minor mods.
I've placed a 3mm spacer between the main bearing and the platter. The RB250 rides too high at the pivot end of the arm and I needed to either bring the arm down at the back or raise the platter a smidge to get the VTA right. Lowering the arm was not possible, so I raised platter instead. The spacer is actually a circular aluminium Linn armboard for the deck, which came as a spare when I bought it. I did worry that it might affect the speed (it going to add a very small amount of extra tension to the belt), but I needen't have as it doesn't seem to have affected it adversely.
Goomer spoke to Michell about using an RB250 with the Focus One and they said they didn't recommend it because of the VTA problem, but I seem to have found a workable way around it and the Rega does sound excellent on this deck.
I also found the bouncy feet rather disconcerting and given that the deck is very reasonably isolated anyway, I turned it into what is effectively a non suspended deck by using some solid coned Gyrodec feet instead. I found it also tightened up the bass a fair bit.
I've been thinking about maybe doing something with the motor (OL live maybe), but to be honest such a mod would cost more than the deck is worth, so I'm not sure if it would be a good move. Seems to me if I wanted to spend that kind of money then a new Tecnodec might be a better idea.
Another possibility would be to swap out the bearing for a Tecnodec bearing (apparently it'll work), but if you look at the Focus One bearing its very well engineered - the bearing and platter are pretty damned good in the first place, so not sure how much difference it would make.
