- Dec 11, 2003
Share info - B&W VA100LS Amplifier
Hi guys,
Just sharing some info with you.
There are no signal output of B&W VA100LS Amplifier.
You might check and found out -
Problem 1. the gate voltage of the power transistor FET2 and FET4 are close to 0 volt.
Action taken -
First of all just check with the reference voltage which supply by Q2 and Q6 are there +13 V and -13 V at emitter, if yes then Q5 and Q7 may not working.
you may unsolder the 2SK1058 and 2SJ162 after replaced Q5 and Q7.
Use a jumper cable to jump the gate voltage R50 back to the NE5534 feedback network R77 and measure the voltage at R92, try to adjust bias voltage via VR2 you should get smooth voltage output like 0 V to - 2 V.
And next
Use a jumper cable to jump the gate voltage R92 back to the NE5534 feedback network R77 and measure the voltage at R50, try to adjust bias voltage via VR2 you should get smooth voltage output like 0 V to + 2 V.
* please turn off the power and wait for 30 seconds for power discharge before jumping the cable.
Then you may solder back the 2SK1058 and 2SJ162.
Problem 2. after fixed problem (1) the speaker protection circuit will on and the unable to adjust the gate voltage via the VR2 after all.
the gate voltage will increase with uncontrol while turning VR2
0.000 v
0.001 v
0.050 v
0.111 v
0.799 v
1.532 v
for a very small tune, less then 3 degrees and the gate will reach to maximum point. Usually, you need to tune at least 30 degrees to get 0.680 V which apply to the gate of FET2 2SK1058 power transistor.
To resolve this problem just check with - resistor R56 (10 ohm) might be open.
Cheer
The Schematic circuit diagram of B&W VA100LS amplifier (partially)
Hi guys,
Action taken -
And next
0.000 v
0.001 v
0.050 v
0.111 v
0.799 v
1.532 v
Cheer
