Should I use a Lavalier microphone or DJI mic for this setup?
Singapore
Hi there,
I'm looking to record sounds of the environment through mini glass tube "sculptures", with openings on the top and bottom. the largest hole size is 4-5cm and it has the longest length is 6cm. Therefore, I'm looking to see how I can insert mini microphones through these glass, to record sounds. Would a lavalier microphone be appropriate for this? I'm thinking of getting a RODE Lavalier PRO and connecting it to the Zoom H2N, and recording the sound through there. but i will need some advice on whether this is a good set up.
Image ref:
