STELLABAGPUSS
Happy Chappy
Just thought I would report in, and let you know what I've been up to. I've just re-wired my Monitor Audio 20SEC Speakers, inside I discovered QED 25TH Ann Cable, so out came that, and replaced with 4n 99.99% Solid Silver. Straight away, a big improvement in speed, and gone is the bloom in the lower frequencies.Also major improvements in the Mid Range Department.
The following day, I re-wired my Mains 4 Way Junction, and my Amp Mains Power Lead and CD Transport Lead. I purchased all the lead on ebays, and although I was pretty happy, TBH the DIY bug got the better of me. So... I got my Dremel out and cleaned all the plug pins ,Fuses,and juction box up. Removed all that rubbish that they Tin plugs with, then gave everything a nice blast with Cillit Bang....leave for a hour, wash off with water, dry then gives everything a clean with Kontak. I also discovered that again QED cable was being used in the mains cable and 4 way junction! I then rewired the leads using again 4n Silver, 2.5mm on Junction and 1.5mm on Amp and CDP Transport.
Switched back on....and Im quite surprised. Very Clean sound, and TBH a Little hard and Bright and harsh and a lean bass. Although big improvements in the Mid and High, and imageing.I'm certainly hearing things I've never heard before.
Of course I have to be patience, all these changes in 2 days, I suspect I will have to give all the cables time to burn in ?? I hope this is the case, I will report back in a few weeks time.
