Software to run plug-ins on a MacBook output
Hi guys,
Until now, I've been running on a Windows computer. I used APO Equalizer that takes the sound from the computer (i.e. Spotify, YouTube,...) and enables to run plugins on that mix and outputs on the main output of your computer. I simply used that tool to run parametric EQs, exciter, enhancers and moderate reverbs for music.
I will soon be investing into a MacBook. Is there a way to do the same? What are the different options? Use an external sound card with Pro Tools? Or is there a way to do it using Ableton Live?
Thanks in advance for your help!
Yann
