Hi there
I'm looking to buy/make a small tool/stand to assist with soldering - basically something with a crocodile clip type attachment on the end of some bendy-yet-rigid wire.
I want to use it to grip the item(cable) to be soldered still whilst my hands are busy holding the solder and the iron - does a readymade item exist amd, if so, where can I get it?
Apologies for the dumb question but I'm fairly new to the DIY-side and could do with some help.
Cheers in advance...
