the standard 240 5pin din plug will fit the base of the tonearm suitably equipped. If and this is a big if you remove the body of the standard plug ......
I propose to take a standard plug [female 5pin 240] strip it down so I'm left with the connector block [for want of a better word] wire the pins up then epoxy putty it into a 10 mm plastic pipe.. total cost just shy of £4 [assuming you have the other bits to hand]
Most tonearm plugs have a small peg or pin to locate the plug in the socket ...its not essential if you have reasonable access to the pillar base ...
results so far using this method have been very promising
using simple silver in ptfe, may be a tad too forward in the mid for my taste but for an outlay of less than £30 this will kick most standard tonearm cables well into the long grass. Replacing the standard nema cable it was clear how little of the music the stock cable was allowing through ....for Uncle ants it was quite a revaluation...[but with the nod towards the previous mentioned forwardness] Quite what is causing this is difficult to say with out further cable experimentation
