Sony CMT-SPZ90DB Sound output problem
Hi
I have a Sony CMT-SPZ90DB and there is a problem were there is only sound when I use the headphones, no sound out of the speakers !, any idea what the problem could be ?.
Spike
Likely to be a protection relay or similar device that is stuck in the open position so no sound gets though to loudsepeakers.
You need a Service Manual, or at least a circuit diagram to analyse.
As the headphones work, the fault won't be serious, a tech should sort it out fairly easily.
S
S
Hi
Thanks for your reply, have just got the SM for it, will have a good look when I get home from work.
Spike
Hi
Spike
Amp Board !
4 Brown parts are 9 Z65-105 , the 4 grey parts are ( C100-YS ) have no idea what the latter is !, is there a component on there that would act has a protection/overload ?, there is 2 components top right marked (MF) have no idea also what they are .
Spike
Hi
All sorted now, there was a factory reset sequence that I have managed to find and all is working good, I am a very happy person today, thanks for all your replies .
Spike
