I'd be most interested if anyone here tried the following mod on their speaker cables and can say what the difference was?
Its from
http://www.tnt-audio.com/clinica/ubyte2e.html
Text excert;
"PS. If anyone uses Speakers without HF Impedance Correction, get an 6.2 Ohm Carbon Composite Resistor (2Watt - non inductive) and a 0.47-1uF Siemens stacked Film Capacitor (or equivalent) and connect these across the cables at the Speaker-end.
If you use NAIM Amp's (or others that warn you about using highish capacitance cables) make three turns around a 6mm Core (say a piece of a cheap plastic Biro) in each of two leadout wires at the Amplifier side, and connect a 10 Ohm, 0.1uF Zobel across the cable at either side of the small Inductors (making a symmetric PI Filter in essence)."
Its from
Text excert;
