I have this beautiful micro system from I'd guess about 20 years ago and both drivers have the rubber rings completely disintegrated. I checked pricing for reconing them and it looks like it will be at least $90/speaker. Can someone suggest a good replacement and/or share further thoughts?
Here is some info I could find. The model number on the back of the original driver is T8P17A6, which seems to be long discontinued. The specs I could find in the product manual are as follows: 8 cm (3 1/8") cone type with 6 ohm impedance, 35W input for music, output pressure level of 82dB/W at one meter. The frequency range is 53Hz - 25kHz (-16dB) and 61Hz - 22kHz (-10dB). Any and all suggestions will be appreciated.
