Speakers positioning query.
nak
I don't post very often but i would like to pick your brains if i may.
Is it ok to put my floor standing speakers either side of a log burning stove? I'm thinking of the heat and possible problems.
Anyone have a similar set up? have you had any problems?
nak
It depends on how close you want to put the speakers to the stove. I had a pair of avantgerde horns either side of a stove without problems.
10729728473ff4442f246cb
If you would feel comfortable sitting there all day long, then the speakers will probably be okay too. If you would find it uncomfortably hot, then its a bit close.
I notice great differences in sound depending on the temp. Over warm and the music sound's that way, too cold and the music can sound's harsh and uncomfortable.
Keep the burner going steady i suppose...
Thanks for your advice.
The speakers are about 33 inches away from the sides of the log burner. I'll see how things go when the fire's glowing.
nak
pic_popup.php
The link shows my horns next to the Coal burner. They were fine.
Nice!
I'll post a pic when the room has been decorated and its all put back together.
nak
One more thing. Now the hifi will be at the side whats the best way to cope with the extra cable for the closest speaker?
the only downside to uneven cable lengths in real terms, is resale value. I seriously doubt that anyone would be able to here the difference in a few metres of high purity copper cable
