I'm close to springing for a Squeezebox. Current PC setup at home is a wired network using a good ole Linksys router. The music server PC will reside in a different room from the hifi. The network wiring will be a hassle so I prefer to eventually use the SB in a wireless mode.
But...do I buy the wireless SB now and get a wireless router in the future or get a wired SB now and do as Silm Devices customer support suggests:
My Question: "Is it possible to add the wireless support to a regular wired Squeezebox after purchase?"
SD Answer: "Unfortunately the wired Squeezebox cannot be readily upgraded to a wireless Squeezebox. The best solution would be to purchase a wireless ethernet bridge. If you purchase an 802.11g bridge, you will be able to take advantage of extended range and increased bandwidth compared to the wireless version we sell which only supports 802.11b."
My understanding of this is that the wireless bridge would have to be connected to the SB via a Cat5 wire and I'd still have to get the wireless router anyway. Correct?
Does it make sense to get the higher bandwidth of the g spec gear or is b spec perfectly adequate for streaming CD quality data?
What about the future? I assume the SB will eventually get the higher spec networking but not sure when.
Any advice greatly appreciated.
-Peter
-Peter
