Stello U3 24/192 USB DDC Link Digital Interface
Igloo Audio
Trade Member
Tunbridge Wells
The Stello U3 is likely to be the best USB to S/PDIF or AES interface converter on the market ;) By using customized X-Core 32 Bit/500 MIPS microprocessor from XMOS and super low jitter 2 external clock generators, the Stello U3 serves as the finest bridge between your PC and DAC. The U3 supports all the files up to 192kHz/24 bits.
Review: 6 Moons (which includes the market leading Eximus DP1 DAC).
Price: £365 Inc VAT
Purchase: http://www.iglooaudio.co.uk/product/stello-u3/
Picture:
Technical:
- Asynchronous synchronization mode, High Speed Bit Perfect Audio Data Stream up to 192kHz sampling rates
- Super low jitter 2 external clocks
- 22.5792mHz/24.576mHz for multiples of 44.1kHz/48kHz sampling rates
- Standard sample rates 44.1, 88.2, 176.4, 48, 96, 192kHz/24bits Audio
- 1 USB 2.0, Type B connector, Galvanic Isolated, Up to 192kHz sampling rates
- 1 COAX 75 Ohms, Gold Plated RCA Connector, 1 AES/EBU 110 Ohms, Neutrik XLR Gold plated contacts Lock indicator: LED on the front panel
- Customized Windows Driver : Windows XP, Windows Vista, Windows 7, Natively supported by Apple Mac OS X
- 100 X 36 X 100mm (WHD)
Yours,
Igloo Audio
