Pretty much any cartridge with a standard 1/2" fixing will work. The arm on that turntable is quite good, so you can fit anything from an AT95e at around £40 to anything you fancy.
One of my favourite MM cartridges is the Goldring 1042, which currently sells for £365.
Moving coil cartridges generally will prefer a higher mass arm, so I would stick with MMs.
S.
