Terminator for Unused Digital Outputs
For decades it has been mandatory to use terminators in 10Base2 Ethernet networks that use coaxial cables and BNC connectors.
The purpose of the terminator is to absorb signals so that they do not reflect back down the line.
RF impedance theory says that if a transmission line is open circuited; it will have reflections at certain frequencies. Since the digital output signal has a wide range of signal content with regard to the frequency content, it will have some signal reflected. This reflected signal can back feed into the input of the digital output circuit (no circuit is perfect, and none have infinite input/output isolation) and then back into the rest of the digital circuitry, causing jitter.
A terminator used in Ethernets is a 50 ohm resistor is readily available to purchase. However, coaxial digital outputs of CDPs, DACs, DVD players, AV amps/receivers, etc require a 75 ohm resistor and these are very easy to make.
75 ohm resistors are just 1p each from places like Maplins (code G75R). Simply solder one across the terminals of a cheap phono plug. If the unused digital output has a BNC socket you will also need a BNC to Phono adapter (£2 Maplin FA11M).
