timpy
Snake Oil free!!!
Got to listen to my system tonight. I mean really listen, without having to cast a critical ear over a production sample, prototype or something that forms the competition. I didn't play much, some Aswad's Greatest Hits, Tone Loc's - Loc'ed After Dark and some Kellis... yes yes, well I didn't say I was playing music now did I?
Thing is though, it's undergone so many changes since I last actually managed to listen to it for the purposes of enjoyment, that it was almost like listening to someone else's system.
Now in the back of my mind, there's been a list of things that I think it should be better at, and whilst it is good at making up the numbers in the weight of such and such modification / cable / tweek etc. performs like this in X many systems including mine, it does still have some definate sonic traits, and my actual familiarity with it seems to get less and less.
So effectively, with the launch of an upper range of cables, it's had the opportunity of cost-no-object cabling, both of ours and our performance competitive references, and many have wriggled their way in there (Don't tell WM, every now and again he commences a mission to find something and he takes a lot of deflecting
). Anyway tonight, it was that enhanced set-up that I was listening to.
And I was really really drawn into it. And when you think about it, and the cost etc. retail of all the trick bits that were in it, so I blasted well should be!!! It was really good, and quite a bit better than I remembered in every area, and my list of things I think it should be doing better now only a fraction as long.....
....but ....
...and the moral of the story is.....
Well, I was very happy with it before, and whilst it's true, I'm much more happy with it now, the chances are, that in the time that it has been accumulating ever more expensive bits one way or another, I would have been very happy with it whilst they were still accumulating........and buy missing these bits of listening out I missed out on a fair amount of much more cost effective enjoyment.
Now the problem isn't as bad as it sounds, but if I'd actually had to go out and buy all those bits all at once, well it would be quite an investment, and not really justifiable given that I was quite happy with it. All this fancy kit passing through does seem to bring on the upgraditis though, and I'm no more immune than the next man!!
Basically I think the point is; Don't forget to listen and enjoy it!! No matter what state you may think it's in, or whatever upgrade you may be hankering after, just listen to it, because you might, just might, enjoy it nearly as much anyway, just as it is right now.
....but ....
