Very Personal Invention (VPI) Record Cleaner
ricochet...love it !
It's ''positively flash'' next to my DIY record cleaning machine.
I keep meaning to put details up... but the fact is, whenever I think about it I go and clean some more records...
Done about 80 so far... so many left lol....
What's blown me away is how awesomely amazing wet record cleaning is compared to a dry brush... there really is no comparison :O
they are so cheap, so easy to make I really, really don't know why I waited so long....
looks great a really upmarket version of mine you cant beat wet cleaning it sucks out the dirt. can bye an old vac. for 10
dollars then you are on your way.dont be a sucker get going.
Noel W.
Hi Ricochet -
Could you take pictures of inside your machine, details of how you built it?
It would be far better than the version I had intended to make, which is about as cheap as possible.
I think people need to know just how cheap and easy it is to build a wet-vac machine.... and as you already know it's the only way to effectively clean records.....
I really think that now,..
